What would go good with my 12 enphase PV system
gtxkid
Solar Expert Posts: 34 ✭✭
Have just installed 12 BP pannels and have 8 to 12 more i might add to it with but would rather put up a small wind generator instead for now.
Already have a nice 30 foot tilt up pole setup. Was thinking about an Air X unit.
Would like to have it on something simple like my enphase inverters.
Re: What would go good with my 12 enphase PV system
In my limited experience--You are left with the SWEA type wind turbine GT inverter systems... I am not sure they are worth anything (reliability, safety, ability to meet code, actual power output)--but that would be the only thing I can think of at the moment).
SWEA Home Page
Most other wind turbine setups are going to expect to charge a battery bank... You could (legally?) connect a turbine to a Hybrid Inverter System like the Schneider/Xantrx XW system to charge the battery bank (and the XW hybrid inverter does the Grid Tied power conversion)--but that is not cheap or simple.
-Bill "not a recommendation" B.Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
Thankyou
Interesting -
I would wait five to ten years for small wind to mature and become reliable. -
Thirty feet isn't high enough to bother with. You need to get the entire rotor of the turbine at least 30' above anything within 500' of the tower. All the short towers and cheap generators are giving wind power a bad name.
