Hot air collector
Missouri Bound
Registered Users Posts: 5 ✭
Hello to all. I'm new to the forum and I was wondering if anyone has made a hot air collector? I made one last year which seems to work well, albeit undersized for my application. It's 4X8 and hangs on the south wall of my garage. I used an existing window to run the air supply and return pipes along with a control panel fitted in the window. It works well and I was wondering if anyone had experience with this type of collector.
Re: Hot air collector
There are lots of solar heating projects out there for hot air and hot water...
Solar Shed and other Solar Thermal Links
And here is a thread with lots of solar project links and other information:
Working Thread for Solar Beginner Post/FAQ
And this site is very nice for Do It Yourself type projects:
www.builditsolar.com
And Home Power Magazine:
Home Power Mag
Solar Thermal (air and water) lend themselves to DIY projects a lot better than building your own solar PV panels and charge controllers.
We don't talk too much DIY projects here -- but we do high recommend conservation and solar thermal as cost effective solutions to the high cost of energy. Usually a better return on your money type investments than solar PV power.
Re: Hot air collectorMissouri Bound wrote: »Hello to all. I'm new to the forum and I was wondering if anyone has made a hot air collector? ........
I voted last year, I think that counts.
but seriously, check out the link for the solar shed BB listed.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 230 Forum & Website
