The Stecca PF 166
Dave Angelini
Dave Angelini Solar Expert Posts: 7,110 ✭✭✭✭✭✭
Too many folks asking about this so here goes. This unit is a reefer/freezer near 6 cubic feet. I have bought a few of them and Sunwize is the distributor. Stecca is german and the unit is made in austria. They are over three times what a unit from Sears would cost. Offgrid we pay thru the nose for everything so nothing new there.
The units measure less power than claimed. A calibrated Fluke DVM measures 38 watts from a 24vdc nominal. In an 80F garage I am using a shade over .3KWH per day operating as a freezer at 5F.
I'll post a link to a pdf when I get some time later. This is the current state of the art in the world right now! A variable speed DC compressor that is not much bigger than your wallet. And you will need a full wallet! It would be nice if I could order these through the store here? :cool:
    Re: The Stecca PF 166
    Link is below to the Stecca. They are a great company if you are not familiar with them BTW. I have a 24V CFL from them that I think is 13 years old.
    i agree that would seem more to be .3kwh per day. it's seems impressive. i looked at the specs and it shows 1 cold battery. could somebody familiar with it explain this?
    Ahem, yes, I meant .3KWH per day. I do not know what a cold battery is until November?
    I think you'll find a "cold battery" is a thermal mass used to "store cold". Not an electrical device. Kind of a re-usable ice pack that reduces cycling of the refrigerator by "storing up cold" that is "produced", but isn't needed, when the compressor runs.
    Okay? :D
  • stephendv
    I remember looking at these units some time ago when trying to pick appliances for our yet to be built home, and couldn't justify the extra cost. There are already standard AC freezers that use 0.3kWh/day, for less money than the stecca, e.g.:
    - http://www.liebherr.com/HG/en-GB/region-UK/products_hg.wfw/id-407698-0_25118-0
    Or .5kWh/day for: http://www.liebherr.com/HG/en-GB/region-UK/products_hg.wfw/id-407698-0_25118-0
    The 10% gain in using a DC appliance doesn't warrant the extra cost - you could easily make up for it with more PV.
    Stephen,
    As you will find out when you do move off offgrid adding solar panels for day use works well during the day but you have to add capacity to store the energy if you will need it at night. These units were first reviewed in Homepower 2 years back and there still is nothing on this side of the pond that comes close. I wish there were! Show me the light, as well as the data!
  • stephendv
    Hmmm, can't find any of the energy efficient chest freezers in US stores :(
    Funnily enough Liebherr do operate in the US, but they only sell double door monstruous fridges. Whirlpool also doesn't seem to sell chest freezers in the US, neither does Bosch.
    I guess the Steca is one of the few options then!
    BTW, that Liebherr that uses 0.3kWh/day goes for 650 GBP, while the Steca goes for 800 GBP, not as a big a difference as I expected.
    BB. Super Moderators, Administrators Posts: 33,740 admin
    A few years ago, they changed the Energy Star Ratings for Freezers and made them much tougher to get the E.S. rating.
    There are a few E.S. rated 6-7 cuft freezers, the lowest is around 215 kWh per year--Still not as low as this one..
    Thanks Bill! And as we know the devil is in the details and how the testing is done. My data is from a real world 80f room and I would bet that other testing skews the data to average cooler room temperatures over the year. Who knows?
    The one thing I did not add is the energy/KWH used in the winter is so low that I have not measured it yet. Last winter I ran the unit on a DC timer that only allowed the freezer to run during daylight hours. I think I set it to 0 F BTW.
    One of my 48V customers is going to get rid of his propane freezer and run two of these units BTW. Pretty close to the holy grail in the engineering. I would have added the timer and a daytime mode algorithm that ran the temperature colder during the solar hours. Maybe direct run from solar circuitry to eleiminate the battery for the certain users. Being DC there is not any issue with search mode in some of my users inverters which is always nice.
    I will post their energy chart, when I figure out how...
    Here is the energy useage from Stecca.
    (not to hijack away from the Stecca, but....) This last week, I pulled the numbers off my kill-a-watt, that had my 18CF energy star fridge plugged into it. (pure sine xw6048, 117V measured) Over 30 days, I consumed .86KWh each day. Most days, temps were in the low 90's. several openings daily for ice, drink and food. I think I'm pleased, now what will the fridge do in the winter, when the shop gets cold and the fridge portion is not loosing heat, will the freezer thaw out on me ??????
    mike,
    is that with or without air conditioning?
    niel wrote: »
    mike,
    No air conditioning, inside the shop, it gets into the upper 80's daily.
    (fridge is in large shop building, with some insulation.)
    I don't live in a cold area--but from what I understand the modern refrigerator/freezer usually does not tolerate cold conditions very well--The freezer may thaw out because the refrigerator does not lose enough heat to run the compressor enough to keep the freezer cold.
    Mike,
    You will be fine! Bill is right but up here in the Sierra where it does get cold I would say the number is 40F. Different model will behave differently and I would think your location never gets that cold inside a building? The steel building in the background on my webpage link below is probably similar. The notable difference is he is at 6,000 feet.
    So, what model did you get? Anything that size that does under 1KWH per day in summer is really good!
    OK, so here's a shot of the sticker inside the fridge, that I measured .86KWh / day for 30 days 90f summer daytimes. Energy Star Fridge, Frigidaire 18 CF no ice maker installed
    Mike
  • techntrek
    My run-of-the-mill 2nd fridge has this problem. It's maybe 6 years old. I have to adjust the fridge dial to make it warmer in the winter to keep the freezer frozen, then reverse in the summer to make sure the fridge compartment gets cold enough. Its in my garage which is in the 80's in the summer and below freezing in the winter.
    mike90045 wrote: »
    Mike
    Thanks Mike for the info! In the original post you said you measured it for 30 days and above 3 days? Is there a typo? Never mind I think I am seeing things........... --Dave
