Need a Solar well pump
AnthonyH
AnthonyH Registered Users Posts: 18
Water Well info:
500' depth
405' to water
8" casing to 20'
5" casing to 460'
Steel & PVC casing
5+ GPM flow rate
any links to the Wind & Sun store for a complete setup/kit? This will be a self install, if that means anything.
    Re: Need a Solar well pump
    Well, at least you are not trying to get a lot from that depth. I assume you will have a storage tank above ground, that you will feed a pressure system from ?
    Solar is not a good solution here.
    If I'm reading your post correctly, you need to lift water over 400 feet @ 5 or more gallons per minute.
    That's in the 1.5 - 2 HP deep well 240VAC pump range; heavy duty stuff. Solar does not make a good choice for powering such equipment because it would be very expensive (1.5 kilowatts @ 240 for running, and perhaps as much as 5 kilowatts for start-up).
    That lift is daunting even for the "slow rate, store it in a reservoir and use a second pump to pressurize the system" design.
    If we had a few more details about the application we might be able to come up with a better solution.
    If you have grid power available, that is the better solution. :D
    Otherwise, the occasional generator run might be the way to go.
    Dave Angelini Solar Expert Posts: 7,012 ✭✭✭✭✭✭
    Call wind and sun and talk with Michael Mady or a technical person. There is no reason that this can not be done with solar (sorry marc) and you probably will end up with a grundfos. Marc is correct that if you have utility power with in $10,000 of distance or you love doing generator maintenance they are the way to go. It is really a personal decision also.
    We go 1000 feet deep quite often up here in the Sierra mountains. Rain water also looks very good if are not a gambler!
  • BajaGringo
    BajaGringo Solar Expert Posts: 40 ✭✭
    Some kind of online calculator would be handy for such kinds of things. I was looking at trying to come up with a setup to lift 1.5" pipe 60' feet, 24/7. It is for an abalone farm on an island off the coast of Baja California, Mexico. There is good wind so the solar could be helped out to support the batteries when the panels weren't charging...
    Dave;
    I didn't say it couldn't be done, only that it tends to be expensive. Your $10,000 figure confirms this. :D I'd hate to invest that kind of money just to pump water. Since we don't know any further details about the OP's situation (including budget) it's hard to say what is the best solution for him.
    I pump with solar. There are no electric lines anywhere near. My system cost $10,000. But it also runs everything else! :D
  • stephendv
    BajaGringo wrote: »
    Grundfos have an online tool to help size their systems: http://net.grundfos.com/Appl/WebCAPS/InitCtrl?mode=18
    The sqlflex range is under the "renewable energy" section
    Dave;
    I just did not want the op to think that he had to produce AC power which you were sort of infering. The grundfos deep well gear is just over 100vdc for near 5GPM. You do need quite a bit of solar and anything that deep is expensive. I have a customer that spent three times that for smelly iron laden water. To treat the water was kind of a "BP affair" with dangerous chemicals and lot's of electricity.
    He now drinks rainwater and uses the well for the yard.
  • icarus
    If you have good wind, why not avoid the middle man, and use the wind to pump directly?
    Wind has been pumping water from great depths for thousands of years.
    BajaGringo wrote: »
    are you pumping from ocean to a 65' high tank farm ? or just pumping up cold water from deep, to farm with ? Simple air lift pump can do that water movement, like an aquarium filter, 65.5' high pipe, and 6 feet down, you hang an airstone, and let the air bubbles pull the water up from the deep. And it oxygenates the stale deep water too.
  • BajaGringo
    The idea is to pump water from the ocean into the abalone seed holding tanks that will be at most 60' above the low tide mark. We need to maintain a flow of around 50-75 gallons per minute. I hinestly hadn't thought about air lift - worth looking into...
    BajaGringo wrote: »
    The idea is to pump water from the ocean into the abalone seed holding tanks that will be at most 60' above the low tide mark. .......
    I don't think airlift will get you 60' elevation gain :(
    mike90045 wrote: »
    I think you're right. Somehow the figure of 32 feet comes to mind. Something about atmospheric pressure.
    Apparently, you need to between 1/3 and 1/2 of the "well" under water... So, if you want a 100' lift, you need upwards of 100' underwater (200' of pipe).
    There is one company, at least, that makes wind powered air compressors (don't know anything about their product). This particular pump has about a 300' maximum lift (website is kind of sparse).
    Airlift Technologies
  • icarus
    Wind powered mechanical water pump (old fashion rod pump) like those that dotted the american west for nearly a century. (Aeromotor??)
    http://www.aermotorwindmill.com/
    http://airliftech.com/ (Says it will pump 315')
    Sources:
    http://web.mac.com/kenobrock/iWeb/Site/Home.html
  • AnthonyH
    not sure how my BUDGET fits this equation, sounds to me like the repairman who charges folks by the type of neighborhood or vehicle parked in the driveway.
    We do have a 7.5kw system out there that is for the outbuildings and house. Maybe we could run a line out to the pump from this?
    Thanks for the links Icarus, after looking at the links and pricing, we are almost at the same costs as the $10,000 price quotes on the 220VAC pumps.
  • icarus
    AnthonyH wrote: »
    The difference however is that the 220 vac pumps have on going energy costs that are not insignificant, while the wind only has maintenance cost. (As does the 220vac system)
  • azrc
    azrc Solar Expert Posts: 43
    I am looking at something similar and found MODEL SCS 10-400 which claims to be able to pump at
    PSI |FT |GPM| Panel Watts | Efficiency
    220 |508| 5.6 | 1913W | 35%
