Need Help with 3-Line Diagram
Hi,
I've had experience installing solar with other companies, but I've now just gone off and began managing my own projects.
Can anyone send me an example of a 3-Line Diagram for a single string using Enphase Microinverters? I know I need this permits, but does it have to be certified by a PE. Is there any templates to help people draw these diagrams?
I'm starting from scratch and I would appreciate any help people can give me.
    BB. Super Moderators, Administrators Posts: 33,716 admin
    Re: Need Help with 3-Line Diagram
    As far as I know--The PE (Professional Engineer) will be required for the panel mechanical racking--not for the electrical design/drawing.
  • jimwilks
    jimwilks Registered Users Posts: 7
    By "3 Line Diagram" are you referring to the wiring diagram/schematic?
  • drees
    drees Solar Expert Posts: 482 ✭✭✭
    Enphase has very detailed 3-line diagrams for each one of their inverters on their website in the support/downloads section. The pictures they use to represent each component are a bit more detailed than is typically required - you can usually get away with simple boxes for each component with labels/descriptions for them.
