Brown electrolyte in batteries :cry:
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
I know it can't mean anything good
About half my batteries have 1 cell, with brown electrolyte. Other cells in same battery are nice and crystal clear.
Any guesses as to how long before I have to get new batteries ?
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Brown electrolyte in batteries
Mike,
How is the SG ? balanced between cells? Are you being hygenic? Have you ever uncovered the plates? Last, did you get the e-mail on how to mod your XW for single phase? Is it 5 o'clock yet... oh yea, are you sure the electrolyte is dark?"we go where power lines don't" Sierra Nevada mountain area
Likely it's caused by eroded plate material that settles to the bottom getting stirred up by pieces of plate dropping off; plate failure.
Run 'em 'til they drop.
Which could be today. -
Re: Brown electrolyte in batteriesDave Sparks wrote: »Mike,
Did not test SG.
I took a dip in the creek, but I had a rash for several days afterwards
Batteries were used, AFIK, plates always covered
Got the email
It's 5 o'clock somewhere
electrolyte is a murky muddy brown. Other cells, are crystal clear as I would expect. 8ea, 6V batt in series.
I'll run them till they fail .Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
If you did not test the SG Mike, how do you know the electrolyte is dark? Did you remove some with an eye dropper? I understand that when you look into the cell it is dark, and I really understand it is 5 o'clock somewhere, but I do not understand yet if the electrolyte is dark? There is a reason but you have to play along until 5."we go where power lines don't" Sierra Nevada mountain area
- 231 Forum & Website
