Re doing the Battery Box
Re: Re doing the Battery Box
Harbor Freight hydraulic crimperThe trick with the hammer crimper is to put it on a hard (massive) surface, anvil is nice, and hit it HARD with a heavy hammer. I use a ~3# hand sledge and it works great!
Harbor Freight or Northern sells a pretty inexpensive hydraulic crimper, but I suspect the quality is not real good.
work great
the size of dies r off do
but i love the one i got -
The hammer crimper is just a small, portable crimping. It does a good job when you cant carry a large crimping tool. It did not know that was from NOCO. I have been using NOCO Battery Boxes (large battery boxes) for housing my batteries. It savings alot of time from making my own. They have dual L16 battery box that works well. You can get the dimensions from www.noco-usa.comThe trick with the hammer crimper is to put it on a hard (massive) surface, anvil is nice, and hit it HARD with a heavy hammer. I use a ~3# hand sledge and it works great!
Tony -
If you are going to put all the positives together on one bus bar, and all the negs together, you are going to have a 16 cell 6 volt battery!
If you are going to 48 vdc you are going to need to string 8 L-16s together in series (+to -to+ to - etc) and then connect that to a second identical string, making 2 48 vdc series/ parallel batteries.
Tony -
Discussion about battery fusing/connections moved to its own thread here:
Trying Off-Grid Solar Again, Looking for Guidance
