Solar Powered Jet pump
Texas Wellman
Solar Expert Posts: 153 ✭✭
I am a licensed pump installer in the state of Tx. I was looking for a solution to using a jet pump installed on a 2" well using solar power. A 4" or 3" grundfos will not work in this application.
Does anybody have any experience with the sunpump line of centrifugal pumps? I was looking at installing their shallow well jet pump with 6 panels. The static water level is very high for this application (~10 ft) and there will be no pressure, water will be fed directly into a cattle trough.
Thanks for your help.
Re: Solar Powered Jet pump
I was hoping some one would chime in on this one.....looks like I get to be the first. -
I am on city water--So I am not much help. The little I have read here over the years seems to indicate that Sun Pumps are fine. The company offers quite a bit of engineered solutions for DC powered brushless pumps/motors--Pretty interesting.
Here is a Google Search for "Sunpump" on this forum for the few other threads about them.
Our host NAWS carries SunPumps--Perhaps talking to them directly can help you.
Re: Solar Powered Jet pumpTexas Wellman wrote: »I was hoping some one would chime in on this one.....looks like I get to be the first.
I sent you a pm with my info. -
PM replied.
Any more info?
