Panel Mounting on roof
bart
Solar Expert Posts: 30 ✭
I'm trying to plan where the panels and mount will be locate. I have a question regarding mounting at the top of the ridge. Can the panel end protrude past the ridge? Right now I have it plan so that there is only 9" at the bottom of the roof. I was wondering if I could slide the panels up the roof so there is around 30" at the bottom. However this would cause the top panels to protrude 21' past the roof's hip line. I hope I'm clear enough on my explanation - Here's a picture
Thanks, Bart
http://icpage.com/images/RoofLayoutLandscape1.JPG
http://icpage.com/images/RoofLayoutLandscape2.JPG
Thanks, Bart
Re: Panel Mounting on roof
Go with #1 layout. With the panels above the roof line, wind will break the top row.
Now before you even start, take drawing #1 to your local fire department and see if they have any problems with 90% of the roof covered with panels.
Some departments like to see 30-40 inches of free space from the top of the roof so they can cut holes to vent the smoke out when there is a fire. -
Thanks for the reply. Plan one it is. I did check with the city inspector about the "3 foot rule". They told it applies in commercial installs, but not residential and that the other side of hip line was open for the FD. I'm going to double check before I drill a ton of holes
Bart -
If I were you, I'd mount them portrait orientation because the mounting rails are going to be horizontal across your roof trusses right? Much better support for the rails that way. Makes the array 3 modules high which is 16.3 ft -
Ok, trying portrait on paper. The only problem is that 3 need to landscape at bottom. Not sure it solves anything. I have 33 panels.
Bart -
I would stay with your first plan and share the rails between horizontal rows
Also, try an get a 1-2" air gap between the panels horizontally, otherwise the lower rows can super heat the air that would have to travel all the way to the peak. -
Now slide the top row over the top of the hip -
Why place the combiner way at the top, why not at the low end ?
What about shade ? does your other section of roof shade the array evenly, or the top or bottom row first ? May want to fiddle with how panels are wired so shade only impacts a single string at a time, not all three at once.
And you basic roof underneath, how old is it - is it worth considering rerofing before you install panels, or at least do the valley and the exposed lower parts before the panels go up.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I put the combiner at top because it was closet point to inverter. Luckily there is no shading problems. I had the roof inspected, so I we are OK there.
Thanks for your input
Bart -
Will the inverter get adequate shading and cooling? For every 10C (18F) you reduce operating temperatures, you roughly double the life of the electronics (20X = 2*2=4x longer life).
Re: Panel Mounting on roofsolar_dave wrote: »Now slide the top row over the top of the hip
You think I'd be OK hanging over? I suppose I could secure end with long mounts, however it should be fair rigid mount to the rails
Is there any code violation extending past the ridge somebody know of?
Thanks, Bart -
You won't be able to meet the wind load requirements on the racking with having the panels over the peak. Uplift is bad enough but going over the peak and you have 100% of the wind energy being applied to the panels, for sure can't meet code on that idea -
Re: Panel Mounting on roofWill the inverter get adequate shading and cooling? For every 10C (18F) you reduce operating temperatures, you roughly double the life of the electronics (20X = 2*2=4x longer life).
I believe so - The inverter is mounting on the north side
Bart
- 611 Discussion Forums/Café
