solar powered fountain
I love the idea of a solar powered fountain for my garden. Can't seem to find any useful information. Any body know how i could do this? How big would panel have to be. I would like to move column of wter about 24 inches.
Re: solar powered fountain
http://www.harborfreight.com/solar-powered-fountain-pump-66093.html
That's about as easy as it gets.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: solar powered fountainhttp://www.harborfreight.com/solar-powered-fountain-pump-66093.html
The problem with this one is I have one. They SUCK. I bought it on ebay for 10 bucks and basically I wasted my $$. I use it daily BUT on a scale of 1-10 I rate it a 2. Yes, it does work, NO it doesnt have a battery so only when direct sunlight is on the panel do they work. The TINY holes constantly get clogged and I have to clean it everyday. (the holes) It realistically only goes maybe 9 inches above the water and if your pond is deep (mine is 2 ft) then you have to stack bricks in it to get the little pump to sit on it. I dont recommend this pump. I am actually looking for something else to replace it. BTW it also doesnt have a filter so NO help from it in cleaning. Just thought I would voice my opinion.
- 232 Forum & Website
