Micro Inverters on not?
bart
Solar Expert Posts: 30 ✭
I have 2 quotes for basically the same size system at 6000 to 6900 Watts. One is using (15) Enphase D380 and the other is (1) SMA 6000 - Both include (30) 230w Yingli modules.
The price is slightly higher for the Enphase (but less than 2K).
I sort of like the Enphase install as it seems more (1) DIY friendly, (2) there is no single point of failure, (3) It appears to be more easily expandable.
Can anyone give me your thoughts on these two design?
Thanks, bart
Thanks, bart
Re: Micro Inverters on not?
We have had a lot of discussions about Enphase (see Google search here).
Short answer, many of us a bit leery of installing a bunch of small inverters under solar panels on the roof and prefer the idea of a single (or pair) of large inverters mounted down on a wall someplace in shade/cool. Just don't know how long the Enphase will last in those conditions and replacing one large inverter on the ground seems easier than pulling panels to replace on on the roof.
The other issue you may want to look at is monitoring... Enphase charges a bit for each inverter per year to access their website full of your data. You can access the data without their subscription plan--but it may not be very user friendly or very detailed.
Pretty much your choice... They both will work and they both have their pluses and minuses.
The one real potential plus of an enphase system as I see it, is if any or all of the PV panels are subject to shading throughout the day or year. In the case of some partial shading, the enphase might be better at real world harvesting of power.
That said, if partial shading, or different facet installation is not an issue, I agree with what Bill says,, advantage single point inverter(s).
Tony -
according to this
http://www.enphase.org/downloads/Enphase_D380_Datasheet_101509.pdf
Its a maximum of 380 watts AC ... but your connecting 460 watts of PV. Also, hooking up multi-panels to a single inverter is in essence defeating the number one claim of these inverters, that being a panel shaded won't effect the the other since its sold as a one to one solution, not 2 to 1 as you have been quoted.
If you want micro-inverter, stay one to one and make sure the inverter can transfer all the energy the panels could provide, my guess when you properly configure using the correct inverters ( you need 30, not 15 ) , your looking at more like a 5-7K difference with no benefit unless you have bad shading.
I'd say go with the SMA, number one inverter manufacture in the world -
Re: Micro Inverters on not?Solar Guppy wrote: »Its a maximum of 380 watts AC ... but your connecting 460 watts of PV.Solar Guppy wrote: »Also, hooking up multi-panels to a single inverter is in essence defeating the number one claim of these inverters, that being a panel shaded won't effect the the other since its sold as a one to one solution, not 2 to 1 as you have been quoted.
What will work better for this install will depend on a lot of specifics that have not yet been provided. -
Missed that it was two in one ... Seem like an odd package, they cripple it thermally by having two in a single package so you can have less AC wiring? What happens when one of the two inverters fail? -
Wonder if it uses single output H-bridge stage with two separate MPPT high voltage DC controlled boosts. -
Re: Micro Inverters on not?Solar Guppy wrote: »Missed that it was two in one ... Seem like an odd package, they cripple it thermally by having two in a single package so you can have less AC wiring? What happens when one of the two inverters fail?Wonder if it uses single output H-bridge stage with two separate MPPT high voltage DC controlled boosts.
"Does anyone else offers a 15-year warranty standard on their inverters?"
so how much do we know of enphase that 5, 6, 7, or whatever years down the road that they won't pull a sanyo on us and change the warranty? even when keeping it in writing at 15yrs they may wiggle out of it or just up and ignore it, aka swwp.
hopefully this won't be the case, but i have a hard time believing they could offer a warranty that many times bigger than what other quality inverters are getting and yet be under more adverse conditions.
is my memory failing or did i remember it was initially 20yrs for their warranty?in any case the pv will outlast it.
Re: Micro Inverters on not?so how much do we know of enphase that 5, 6, 7, or whatever years down the road that they won't pull a sanyo on us and change the warranty? even when keeping it in writing at 15yrs they may wiggle out of it or just up and ignore it, aka swwp.is my memory failing or did i remember it was initially 20yrs for their warranty?in any case the pv will outlast it.
- 611 Discussion Forums/Café
