MPPT design contest
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
http://www.parallax.com/tabid/847/Default.aspx
So some project/kit house is having a contest to have you design a MPPT ckt for them !
Any takers ?
Any takers ?
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: MPPT design contest
gee, what a prize you'd get while they get lots of $ from your design.:roll: at least they warn you to get it copyrighted for if you don't they probably will. -
First Place Prize – Propeller Proto Board (Serial or USB) + Proto Board Accessory Kit + 6-pack of Solar cells
Yah, that's worth forking over some source code and electrical design :roll: -
Active feedback MPPT: get those school kids that hold the car wash sign to hold a PV with a drop down car wash sign and a DC watt meter attached to the back of the sign. They'll have to till the PV toward the sun to max the watt meter needle (active feedback loop: needle -> eye -> brain -> hand move PV -> watt meter -> needle) They might do it for free for their free shade :-)
GP -
30% of the judging criteria is based on the "ability to use Parallax products." That should tell us something.
Marc
- 621 Discussion Forums/Café
