multi meter
ws9876
Solar Expert Posts: 453 ✭✭✭
Re: multi meter
Nice meter you have there... It will go to 600 VDC but only 10 Amps AC/DC...
http://support.fluke.com/find-sales/Download/Asset/2634043_6116_ENG_B_W.PDF
If you want to use this meter to measure larger currents, you would need to get a shunt resistor and measure the voltage drop (there are different sizes):Deltec 100 amp, 100 millivolt current shunt
Price: $24.00
For the one above, 0.0 mV = 0 amps, and 100.0 mV (0.100 volts) equals 100 amps...
Or, look into a getting a DC clamp current meter (starting around $60 each for one that will do basic DC/AC measurements up to 400 amps).
Re: multi meter
I've just purchased a Klein CL2000. seems to do everything I need, including DC amps and frequency.
