Xantrex Gateway Historian
Joe_B
Solar Expert Posts: 318 ✭✭✭✭✭✭
I was poking around the interweb and found an interesting document on something called the Xantrex Gateway Historian. Seems to be a program that can download data from the gateway. Any of you folks know anything about this program as I am sick of the widget.
Re: Xantrex Gateway Historian
Hey There,
I have used the gateway historian before.
It's basically a data logger, in which you can upload yearly/monthly/dailey totals of your system.
Just put in your IP address into the destination and run the app.
It comes with a spreadsheet exe, which you run, and for the folder you choose, it plots you a graph.
Rgds -
any links to it ? or anyone have the installer ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
joe
Did you ever find the link to the xantrex historian as i would like to download my data.
if not did you try any other monitoring device as i wouldlik eto see what i am producing / using etc
many thanks paul
Digging up an old thread here...
I'd also like to find a copy of Xantrex Gateway Historian. Any information available on how to get that will be very appreciated! Thank you
- 231 Forum & Website
