photovoltaic schematic design
Howdy, Can anyone recommend a software package for creating a PV system schematic for module layout, wiring, etc.
Thanks!
Greg
Thanks!
Greg
Re: photovoltaic schematic design
I've used free software from Express PCB for drawing schematics and designing printed circiut boards. You might want to try it, the price is right!
http://www.expresspcb.com/
John
Others may well know more than I, but it's my opinion that you will be very hard pressed to find such a thing. Reason being, PV systems, in general, are basic, straight forward stuff for anyone familiar with electrical work. Now, I'm not talking about systems that could power a city, just the average home system.
All the best
Wayne -
Openoffice Draw, while not specifically made for PV design, has served my simple needs. With some practice, it's good for both architectural drawings and electrical schematics. I used it because the format is portable, as OpenOffice is open source and available for free.
Just Google "openoffice download" to get the suite. If you have a slow connection, you might want to just order a CD or ask a friend, though - the whole suite is about 200 MB.
My drawings are available at:
http://briefcase.yahoo.com/rmkey@sbcglobal.net
if you want to use them as a starting point for your drawings. Note that OoDraw will output .pdf format, but those are for viewing and distribution - the .odg files are the editable ones. -
I know this topic is 4 years old, but I could use a "template" file to manipulate so I can submit it to my local permit /codes government. Software used is not that important, as long as it can be edited. the above link is dead.
I tried manipulating a PDF file in photoshop, but it's a pain in the butt.
If anyone has one they can share it would be appreciated. -
Re: photovoltaic schematic designrollandelliott wrote: »I know this topic is 4 years old, but I could use a "template" file to manipulate so I can submit it to my local permit /codes government. Software used is not that important, as long as it can be edited. the above link is dead.
I used "Paint", the free program that comes with every windows computer. Took about 2-3 hours do my systems and never had a complaint from the PE or the building department -
Sure it can be done in paint, but it is not a very forgiving program. I guess I'll just stick with photoshop.
thanks for the suggestions. -
Re: photovoltaic schematic designI guess I'll just stick with photoshop.
Re: photovoltaic schematic designrollandelliott wrote: »Sure it can be done in paint, but it is not a very forgiving program. I guess I'll just stick with photoshop.
ggun you are right, but I just borrowed a pdf drawing from the board that was pretty similar so it was easier to do via photoshop
http://www.ige-xao.us/en/us/products/see_technical.php?gclid=CK-v1ujPjasCFak65Qodf3YUyQ
this might work as well for anyone doing it from scratch.
edited to add photoshop is absolutely the wrong tool, but I just happend to know and have it, your suggestions below are better. -
Re: photovoltaic schematic designrollandelliott wrote: »ggun you are right, but I just borrowed a pdf drawing from the board that was pretty similar so it was easier to do via photoshop
If price is no object and you are up for the learning curve, AutoCAD LT is IMO the way to go. -
GIMP is a free, openource, photoshop like graphics editor. Has many of the same features, and, is free.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: photovoltaic schematic designGIMP is a free, openource, photoshop like graphics editor. Has many of the same features, and, is free.
Hi try this plugin for Google SketchUp, it is free and has some cool features to do a solar design with just some clicks.
www.skelion.net
Video: http://www.youtube.com/watch?v=k_tFw...layer_embedded
good luck! -
Just an FYI--"Sam Jankis" appears to be a developer for skelion--So if anyone wants to review the product here--They are welcome. I will leave this up for now as it may be useful for some people (normally, we would delete at spam--that is still an open question at this time).
only reason i left it was that there is a free version. -
These are all smart draw. It has all sorts of new functions if you get it now but I've been using it since it was cheap and simple. I think you can still check out a free on-line demo.
Attachment not found.
Attachment not found. -
here's a free sch & layout program from a PCB mfg company (disclaimer - I do like their boards, and have used them in the past)
http://www.sunstone.com/PCB123-CAD-Software.aspx
you may be able to get it to draw what you want.
This (attached) was done in visio - overkill, but it works.
Attachment not found.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 628 Discussion Forums/Café
