Mixed solar panels
solarvic
Solar Expert Posts: 1,072 ✭✭✭✭
] Now after I bought 2 of the mitsubishi 175 w panels they have become obsolete. So now I want to get 4 of those Shuco S SPU-4 180 panels that are suposed to be obsolete to run with the mitsubushi panels. 2 strings of 3 with 2 schuco and 1 mitsu.
Mitsubushi PV-UD175MF5 Schuco S SPU-4 180 watt
maxium pmax 175w 180
output tolerance +3%-3% +5%-5%
warented minium 169.8 minium from string chart ptc watts 161.6
VOC 30.2v VOC 30.4
ISC 7.93A ISC 8.03A
VMP 23.9V VMP 24.2V
IMP 7.32 IMP 8.03
module efficiency 12.7 13%
Does this sound like a good match with 2 strings?
1 mitsubishi panel with 2 of the sdhuco panels per string? If i added 1 more string consisting of 3 shuco panels would it make too much of a mismatch. What I want to do is charge 1 set of 4 400 amp l-16 batterys for 24 volt or 1 set of 8 batterys at 48 volt. Leaning toward using the sw 4024 inverter with 1 set of 4 batterys. I have a gaswell that I am trying to make use of and want to run the generator enough to keep the electric bill close to a zero balance. I don,t plan on exporting any power to utility, just want to dedicate a couple circuits such as furnace in winter and air in summer. I am hoping that just the 2 mixed strings will keep the battery topped off. These solar panels are identical in size and look like twins. S:Dlarvic[/HTML]
VOC 30.2v VOC 30.4
ISC 7.93A ISC 8.03A
VMP 23.9V VMP 24.2V
IMP 7.32 IMP 8.03
Re: Mixed solar panels
solarvic,
now it just might be that i'm getting older, but i had trouble following your train of thought. it may help to post the 158's specs as well. maybe try to simplify what you are trying to ask. -
Deleted all the stuff about the sharp and kyocero panels. I had bought a couple mitsubushi panels to make my string a little higher with my sharps I had. Finally decided to run 2 of the kc 158g which is working ok. I don,t need any help with the sharp and kc 158g panels now.solarvic,
So Now I have 2 mitsubushi panels and was wondering how they would match up with some shuco panels that are also are discontinued. All the specs are in #1 post. Left side has mitsubushi, right side of page has the shulco specs. W I think all information is on post #1 S:Dlarvic -
close enough, go for it.
- 232 Forum & Website
