Algae in Drain Back Solar Heating System
sunny20kin2010
sunny20kin2010 Registered Users Posts: 5
I like the drainback hot water system for raidiant floor heat, but how do you stop all the algae from growing ing the storage tank?
    BB. Super Moderators, Administrators Posts: 33,681 admin
    Re: Working Thread for Solar Beginner Post/FAQ
    Are you sure you have algae growth? I would think that you need some sunlight for the algae to take hold.. You could have bacterial growth--and high temperatures (in the 125-165 F range) should kill much of that (I would guess).
    Are you using city water, your own well water, or some other working fluid (like non-toxic antifreeze) for your system?
    Re: Algae in Drain Back Solar Heating System
    sunny20kin2010,
    I also moved your post to its own thread... Easier to follow your questions/answers.
  • peterako
    peterako Solar Expert Posts: 144 ✭✭
    Hi there i have a twin system. The radiant floor heating, storage and gas heating plus wood stove are pressure 1 ATM. the collectors on the roof are a sepperate system having drain back as requird by local code. bove systems are filled by a mixture from deionzed water and a 10% cooling liquid for cars.
    I do not have any slug settlements or algae in my system.
    Greetings from Greece
  • LucMan
    LucMan Solar Expert Posts: 223 ✭✭✭
    Flush the system with #01311 Purging Compound (Pre & Post Operational Cleaner) then add #01205 Molybdate Based Closed System Inhibitor. available from HeatLink group. www.heatlink.com.
    NEVER use car antifreeze (ethylene glycol) it is toxic.
  • russ
    russ Solar Expert Posts: 593 ✭✭
    İf it is an open system, is it a once through system?
    Add a few feet of copper plumbing. As the copper slowly leaches out, it posions the growths. also stuff a couple lengths in the septic drains, same thing - helps keep roots out too.
    Or some "blue stone" - copper sulphate.
    Copper ridge cap, keep moss off roof.
