winter vs. summer derating table
guy_c
guy_c Registered Users Posts: 7
Hello,
Can someone point me to a resource giving, per earth coordinates, the insulation comparison between winter (sunny day) and summer (sunny day), in a power/area units.
The reason is that I try to figure out the quality of cells I bough before assembling them into panels and, right now (winter in Israel) I find a power which half the announced one (1.7W actual vs. 3.5 announced)
Thank you in advance for your time
Guy
    Re: winter vs. summer derating table
    I don't know if PV watts caculator covers your area, but winter days are shorter, and more air in the path, so power is expected to be reduced.
    http://www.pvwatts.org/
    I don't have anything handy... But you can use a "known good" solar cell and connect it to an Amp Meter.
    When shorted, the current of a cell is proportional to the amount of sunlight on the cell.
  • icarus
    Insolation is one issue, but local weather/climate/cell temperature can have huge effect on output, that may not be reflected in a seasonal Pv watts calculation.
    Local haze, morning fog, cool breeze off of water etc can all have a significant effect. The reality is that most of the Calculators get you pretty close, but every installation is going to be different.
  • stephendv
    PV-Gis is an online calculator that includes Israel.
  • tallgirl
    tallgirl Solar Expert Posts: 413 ✭✭
    mike90045 wrote: »
    Total daily power is reduced, but peak power can be well above STC. I've seen 108% of STC with the cold spell we had here recently. The flip side is miserably hot summer days, and I don't know if PV Watts compensates for hot panels.
  • guy_c
    First I want to thank you all for taking the trouble to answer.
    Special thanks to Stephen; Indeed this resource is what I was looking for. If their calculator is accurate there would be a 1:1.87 ratio from Jan to August
    Special thanks to Bill: This a nice pragmatic solution
    Guy
