I need help
I have been looking for a certian solar power device that I saw years ago in a museum. I forget the name of it, but it was like a light bulb with 4 "Diamond" shaped blades on the inside. They were dark on one side and the other side was light colored. When exposed to light the blades rotated, turning a small turbine and generating an electric current. I don't mean to sound like a total noob, but I am very interested in this device and where I can find them for sale. Please help.
Feel free to e-mail me also: raymondsmall@yahoo.com
Re: I need help
"Radiometer" (?) for $12 + shipping:
http://scientificsonline.com/product.asp?pn=3060082
PS: They do not generate any electricity. There is very little torque and it spins so quickly because it is in a vacuum and has a glass needle bearing (very little friction).Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
Re: I need help
I've got one sitting on my window sill. I will look tomorrow to see if it has any label on it. The way it works is pretty simple. One side of the "turbine" heats, and the temperature difference causes the thing to spin.
No label. My wife suggests that you try the Boston Museum of Industry gift shop.
Tony -
Re: I need help
Actually called a Cookes Radiometer.
Interestingly, there was quite a debate on how it actually works (and is not "light pressure" as I remember from my childhood)... Learn something new every day.
Now--on to global warming.Over the years, there have been many attempts to explain how a Crookes radiometer works:- Crookes incorrectly suggested that the force was due to the pressure of light. This theory was originally supported by James Clerk Maxwell who had predicted this force. This explanation is still often seen in leaflets packaged with the device. The first experiment to disprove this theory was done by Arthur Schuster in 1876, who observed that there was a force on the glass bulb of the Crookes radiometer that was in the opposite direction to the rotation of the vanes. This showed that the force turning the vanes was generated inside the radiometer. If light pressure was the cause of the rotation, then the better the vacuum in the bulb, the less air resistance to movement, and the faster the vanes should spin. In 1901, with a better vacuum pump, Pyotr Lebedev showed that in fact, the radiometer only works when there is low pressure gas in the bulb, and the vanes stay motionless in a hard vacuum. Finally, if light pressure were the motive force, the radiometer would spin in the opposite direction as the photons on the shiny side being reflected would deposit more momentum than on the black side where the photons are absorbed. The actual pressure exerted by light is far too small to move these vanes but can be measured with devices such as the Nichols radiometer.
- Another incorrect theory was that the heat on the dark side was causing the material to outgas, which pushed the radiometer around. This was effectively disproved by both Schuster's and Lebedev's experiments.
- A partial explanation is that gas molecules hitting the warmer side of the vane will pick up some of the heat, bouncing off the vane with increased speed. Giving the molecule this extra boost effectively means that a minute pressure is exerted on the vane. The imbalance of this effect between the warmer black side and the cooler silver side means the net pressure on the vane is equivalent to a push on the black side, and as a result the vanes spin round with the black side trailing. The problem with this idea is that while the faster moving molecules produce more force, they also do a better job of stopping other molecules from reaching the vane, so the net force on the vane should be exactly the same — the greater temperature causes a decrease in local density which results in the same force on both sides. Years after this explanation was dismissed, Albert Einstein showed that the two pressures do not cancel out exactly at the edges of the vanes because of the temperature difference there. The force predicted by Einstein would be enough to move the vanes, but not fast enough.
- The final piece of the puzzle, thermal transpiration, was theorized by Osborne Reynolds[3], but first published by James Clerk Maxwell[4] in the last paper before his death in 1879. Reynolds found that if a porous plate is kept hotter on one side than the other, the interactions between gas molecules and the plates are such that gas will flow through from the cooler to the hotter side. The vanes of a typical Crookes radiometer are not porous, but the space past their edges behaves like the pores in Reynolds's plate. On average, the gas molecules move from the cold side toward the hot side whenever the pressure ratio is less than the square root of the (absolute) temperature ratio. The pressure difference causes the vane to move cold (white) side forward.
Re: I need help
Bill,
You continue to surprise me. The fact that I have one sitting on the window sill is kind of odd, but the fact that you not only know what it is and what it is called is pretty esoteric!
Nice job!
Ps that is exactly right! -
Re: I need help
Thank my parents... Really enjoyed taking us kids to the various museums--and we have had a few of those around the house for years (Hint: kids+glass don't last that long).
Actually forgot what they were called.
Went to the nearest scientific toy website was ready to "display all" solar products--but caught the name as the first "toy" on the page--and thought is sounded right. They have been in displays at the local home center showing that Low-E glass blocks heat transfer (flood light behind glass shinning on Radiometers to show heat blocking).
Computers+Google+High Speed Internet--God's replacement for long term memory.
Re: I need help
"Computers+Google+High Speed Internet--God's replacement for long term memory.
now what buttons was i supposed to push again?
:p maybe coot remembers.:D
