Real Power for 5kw System
Hi. I just found this site and this is my first post. I live about 40 miles south east of Phoenix in Queen Creek Arizona.
My 5KW GT system was commissioned on Dec 28 and here are the Daily KW as displayed on the inverter.
Date
Daily Total
Time On-Line
12/28/09
5.004
8:20
Cloudy all day
12/29/09
14.499
9:47
Partly cloudy
12/30/09
15.295
9:52
Partly cloudy
12/31/09
23.885
9:58
Sunny
1/1/10
22.634
10:03
Sunny
1/2/10
23.262
9:55
Sunny
1/3/10
23.421
9:57
Sunny
I have 26 BP Solar Panels Model SX3190B and a Xantrex GT5.0 Inverter.
The peak power at around noon on a sunny day is about 3400W
Do these numbers look right or should it be closer to 5000W?
Thanks,
Roger
Date
Daily Total
Time On-Line
12/28/09
5.004
8:20
Cloudy all day
12/29/09
14.499
9:47
Partly cloudy
12/30/09
15.295
9:52
Partly cloudy
12/31/09
23.885
9:58
Sunny
1/1/10
22.634
10:03
Sunny
1/2/10
23.262
9:55
Sunny
1/3/10
23.421
9:57
Sunny
Thanks,
Roger
Re: Real Power for 5kw System
I like to compare against the PV Watts program. Using 5kW and defaults for everything else (assuming facing south at 33.5 degree tilt):
For December/January (this is a ~20 year average)--call it 555 kWHrs per month or:"Station Identification"
"City:","Phoenix"
"State:","Arizona"
"Lat (deg N):", 33.43
"Long (deg W):", 112.02
"Elev (m): ", 339
"PV System Specifications"
"DC Rating:"," 5.0 kW"
"DC to AC Derate Factor:"," 0.770"
"AC Rating:"," 3.8 kW"
"Array Type: Fixed Tilt"
"Array Tilt:"," 33.5"
"Array Azimuth:","180.0"
"Energy Specifications"
"Cost of Electricity:"," 8.5 cents/kWh"
"Results"
"Month", "Solar Radiation (kWh/m^2/day)", "AC Energy (kWh)", "Energy Value ($)"
1, 5.09, 564, 47.94
2, 6.06, 608, 51.68
3, 6.61, 708, 60.18
4, 7.54, 766, 65.11
5, 7.53, 773, 65.70
6, 7.28, 699, 59.41
7, 7.13, 711, 60.44
8, 7.17, 720, 61.20
9, 7.15, 696, 59.16
10, 6.75, 707, 60.09
11, 5.59, 587, 49.90
12, 4.88, 547, 46.49
"Year", 6.57, 8085, 687.23
555kWhrs per month / 30 days per month = 18.5 kWhrs per day
You can look at the hourly data output and see what each "average" day would output (load in spread sheet for total per day/week/etc. comparisons).
From the same site, they also have nice PDF files of the data... And you can visually see how much variation per day over 20 years there is.
For January, over the years, the long term monthly average power varies between ~4.0 and ~6.3 Hours per day of sun with an average of ~5.2 hours of sun...
So, it looks like weather wise, you can easily see +/- 20% variation from year to year results in power output.
Looks like a good start.
With solar--your mileage may vary.
PS: From the hourly data--just a quick look shows that you should see an average maximum in early January of ~3,600 watts average for an hour...Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
Re: Real Power for 5kw SystemThe peak power at around noon on a sunny day is about 3400W
I'd not expect to get more than 80% of the sticker mileage !
4940 x 80% = 3952w would be the VERY BEST expected, at the 6 days your panels are aimed perfectly at the sun for 20 minutes. I'm assuming they are fixed on the roof, and not on a tracker, so they only give peak output as the sun moves perpendicular to the panels.
My 4.5KW array seldom got over 3.5KW output, except for a couple days when the sun was perfect.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 231 Forum & Website
