Home made Panel Mount question
machineman
Solar Expert Posts: 129 ✭✭✭
Is it easy to make a home made fixed panel mount by using a large diameter (1.5") galvanized pole(pipe) and rigging some type of attachment brace, maybe some angle iron? I've never closely inspect a soler panel mount before so I don't know how the pole attaches to the panel. The single panel (KC65T) I have in mind is small and only 18lbs and 30inx26in in size. It will mounted about 5feet or so above the ground.
Pole mounts are expensive...
Thanks,..
Thanks,..
Off Grid Cabin, 24V 440ah 6V GC battery bank, Xantrex MPPT60-150 CC, Magnum MS4024 inverter-charger, >1200w Solar bank
Re: Home made Panel Mount question
Panels are expensive too !
Depending on how "crafty" you are, (machineman - ought to be pretty crafty) just building a simple framework for a single panel should not be too bad. However you build it, plan on wind some day, trying to use the panel as a sail to uproot the pole. Nothing should move enough to break anything.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I found a "Two Seas" mount for $71. Proabaly just buy that one instaed of saveing a few $$$.Off Grid Cabin, 24V 440ah 6V GC battery bank, Xantrex MPPT60-150 CC, Magnum MS4024 inverter-charger, >1200w Solar bank
