Unirac or Prosolar???
marks
Registered Users Posts: 17 ✭
As I move forward with submitting my plans, I've yet to decide which racking system to use. Since the roof is concrete tile with a 10:12 pitch, I plan on using stand-offs allowing about 2" between the tile and the bottom of the pv frame. The Prosolar Fast Jack seems like a very clean approach, however their web site doesn't off the engineering specifications that Unirac does. Independent of these observations, do you guys have any thoughts on either of these products? Thx
Re: Unirac or Prosolar???
I'd look for more than 2" if you are in a warm summer area. Keep those panels cool !Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I am sure Cristina @ prosolar can get you any engineering specs. If you have a cement tile roof you will probably have to use the tile track. Both products work well but I have used the prosolar products alot more. Oh, and Mike is right about getting them up off the roof as high as possible.
