It's cold out. Do you turn the heat UP?
JRHill
Registered Users Posts: 525 ✭✭✭✭
According to the New York Times "Climate Forward" email of 1.27.26, "As temperatures plunged and a snowstorm moved across the United States on Sunday, households cranked up the heat."
Really?!? It's from the NYT so it most be correct. Do you turn up the 'heat' when it's cold outside?
Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
It's cold out. Do you turn the heat UP? 2 votes
NopeNo …but I do turn it on😊Off-Grid in Terlingua, TX
5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 650ah LiFeP04 battery bank - 5 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
- 896 Solar Product Reviews & Opinions
