"pass through" inverter
cptdondo
Solar Expert Posts: 107 ✭✭✭
I have a bit of a weird situation. I need a small (300W) inverter to power a wifi access point and a small TV when grid power is not available.
I want to be able to turn on the TV and wifi AP via a switch.
Here's where I'm running myself into circles:
I also want that switch to work when plugged in to 120VAC, and I also want that switch to turn on the inverter but only when I'm not connected to the grid.
So I'm looking for a "pass through" inverter; something like an inverter charger but without the charging circuit.
Does such a thing exist? Or will I have to rig something with an ATS and some relays?
This will be an interesting solution to learn of a small (300w) inverter that can do what the big ones can do.Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
