Feasible to use 3 panels instead of 2 or 4? 48 volt system.
softdown
Solar Expert Posts: 4,048 ✭✭✭✭
Say “45 volt” panels. Currently I only see 45 volt output or 135 volt output when employing three 50 volt panels.
When does voltage become significantly “inefficient” for a 48 volt system? 135 volts too much?
That all depends on charge controller type and voltage range some of the charge controllers in the all-in-one inverters wouldn't even accept 135 volts is being too low so we need to know what charge controller you're using
Considering this one:
POWLAND 80A MPPT Solar Charge Controller,12V/24V/36V/48V Auto,Max Input 150V LCD Display
Almost no way the very inexpensive, light weight charge controllers are going to last for years and years. But I only need additional solar for 2 months out of the year right now. I need to pare down my freezing and refrigeration demands. Takes a long time to empty a freezer.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
At 135 volts open circuit you getting dangerously close to the Charge controllers maximum limit so if you have cold cold weather where you are I wouldn't recommend three in series but why don't you go 2s2p, two in series twice with your four panels
40 volt panels so margin of safety.littleharbor2 said:At 135 volts open circuit you getting dangerously close to the Charge controllers maximum limit so if you have cold cold weather where you are I wouldn't recommend three in series but why don't you go 2s2p, two in series twice with your four panels
No room for 4 panels due to roof adjoining sunroom.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
45 volts open circuit* 3 equals 135 volts at 75° F you put those in cold temperatures like you were talking (-21 f) about they're going to burn up your charge controller
I was guessing at the 45 volts. I have 35 and 40 volt panels. Assumed that the larger panels would be higher voltage. They are lower voltage.I said 40 volts on Aug. 9th post.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
With electrical/electronics... "No Guessing"!
Good point. I’m trying to schedule knee surgery. Climbing ladders can be onerous. Made sense, to me, that panels that are 25% larger would be higher voltage. A clear mistake in retrospect.Now I don’t think there is any way to approximate panel specifics without looking at the information label on the back. Which the sun may have eroded fwiw.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
