F3 error won't stop with float
BillO
BillO Registered Users, Users Awaiting Email Confirmation Posts: 3
edited July 2025 in Solar Water Pumping #1
My Cu200 will not stop pumping even when the float tells it not to pump. Any ideas. I Normally use solar but ac is same condition.
Any
  • JRHill
    JRHill Registered Users Posts: 525 ✭✭✭✭
    It's probably the switch. Disconnect it and see if the pump stops.
    Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
  • BillO
    Yes power off it stops.
    Solar and or AC
    PUT A NEW CU 200 in and same F3 and pumps with either power
    The CU 200 is a version #06
  • BillO
    The float switch will light up but not turn pump off
  • JRHill
    I'm having difficulty making sense of your posts and responses.
