XW+6848 Do not export to the Grid
Luisoler
Registered Users Posts: 5 ✭✭
I am trying to help two friend with XW+6848 that does no export to the grid. These are two totally different installation on different location and towns. One had lead acid batteries and the other Fortress Batteries, Have tried multiple setting and latest available firmware for the +. Has someone experience the same problem and has solved it. Also both systems were used for many years are gird tie with sell option disable. Now has all the approvals for selling and exporting, but the units refuse to sell. Sometimes a short burst of export for few minute, but no more tha 100w. Both systems behave equally.
Go over the settings again. You are missing something in the configuration. Do you have the Insight Device? Good Luck"we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
Both have the Insight home deviceDave Angelini said:Go over the settings again. You are missing something in the configuration. Do you have the Insight Device? Good Luck -
You can post some screenshots here or pay me to go thru the settings. I am in business and can be contacted below."we go where power lines don't" Sierra Nevada mountain area
