Help with open loop batteries
addision
addision Registered Users, Users Awaiting Email Confirmation Posts: 1
I am trying to determine if I need fuses between my busbar and the individual batteries. I have two Sol-ark 12k inverters that will go to two busbars.
I previously had a Fortress 18.5kWh battery, and I recently purchased 4 EG4 Powerpro batteries, and I want to use them all. If I do need fuses, would it be better to go with individual fuse holders for each battery, or with something like a Victron Lynx product?
  • mahendra
    mahendra Solar Expert Posts: 191 ✭✭✭
    Are you using these separately or mixing them? Ie. both the EG4 and Fortress on the same system?
  • Photowhit
    Sounds like you want to mix battery brands/types. NEVER A GOOD PLAN!!!
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,110 ✭✭✭✭✭✭
    Build one inverter with each battery. Follow the install manuals of the inverter and it's battery.
     Probably the only sain way to do this safely.
     Keep in mind that insurance for the structure would want to see this someday if you are insured.
    E-mail offgridsolar@sti.net
