Dug up couple more lithium "systems"
softdown
Solar Expert Posts: 4,081 ✭✭✭✭
Got into this 3 1/2 years ago.
Have BMS and cell balancers.
Plus cables to connect all four.
Too bad I forgot so much.
Dropping from 26.3 to 26.2 volts over ~ 3 1/2 years is impressive. No idea how much life was taken off of the batteries due to storage.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
