Time to retire the Fullriver AGMs?
softdown
softdown Solar Expert Posts: 4,081 ✭✭✭✭
Mfd in 2015. Put in service 2017. Resistance is in the 6.5 to 7.5 range - far too high.
Temp of the bank is 39F though. That lowers strength quite a bit. Unsure about impact on resistance.
I think newer my bank of golf cart batteries is supplying the majority of battery power.
The Fullrivers were awesome while they lasted. Bit heavy ar ~171 pounds. More weight than I want to carry after a prolonged illness.
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,191 ✭✭✭✭
    Are you OK now?
    Marc
    I always have more questions than answers. That's the nature of life.
  • BryceFreeman
    BryceFreeman Registered Users Posts: 27 ✭✭
    To replace it with a lighter one may be better for you as 171 pounds are too heavy.
  • Saggys
    Saggys Solar Expert Posts: 189 ✭✭✭
    Are you considering lithium chemistry for your replacement?
  • softdown
    Are you OK now?
    Marc
    Little better every week
  • softdown
    Yes. Bought a couple 24 volt lithiums at the start of covid. I over reacted. They convinced me it may well be the end of times as we know it.
  • Saggys
    Let us know what you think of the lithium chemistry, as I will probably be going in that direction also hopefully later than sooner.$$$$$
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,199 ✭✭✭✭✭
    You can build a LiFePo4 battery from scratch for less than the cost of new AGM or even FLA
  • softdown
    Makes likely sense if you plan to stay there long enough to justify it.
  • Marc Kurth
    I sell AGM batteries for a living but I often recommend lithium to customers who cannot reach full charge plus some float time often enough. Sulfation rears its ugly head with lead-acid cells. As PV prices have come down over the years I have seen AGM battery banks last longer and longer because folks are buying more PV capacity.
    The "typical" systems that I have seen over the years had a 5-6 year battery life and 10+ years with lots of PV.  Lithium should put longer battery bank life easily within reach without over-paneling.
  • Saggys
    I am waiting for my NIFE cells to let me down, so far, so good. Sulfation does not seem to be a problem, only carbonation.
    I hope to start changing the electrolyte on my 13 year old cells one at a time as I rotate a spare in, that will be the real test to see if they recover from the electrolyte change.
