Exercise the generator that fills in for snowy days!
softdown
softdown Solar Expert Posts: 4,081 ✭✭✭✭
Had not used the generator for a couple years. Today it had to be employed for several reasons:
Solar batteries are expiring
Snowy and cloudy conditions.
So the battery was either dead or the connection bad. Was pretty darn hard to start. Smoky as hell after extended cranking.
Plus I found my 24v charger apparently walked off.
It is comforting to see 53 volts instead of 48 volts. Weak batteries charge fast!
  • BryceFreeman
    BryceFreeman Registered Users Posts: 27 ✭✭
    So what problem your system has? Looks like you have sorted it out.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,199 ✭✭✭✭✭
    They appear to charge fast due to reduced capacity.
  • softdown
    They were manufactured in 2015. placed into service in 2017. I'm afraid to check their specs.
    Though I am running two fridges and 6 freezers. All but one in a chilly to cold environ. One sees somewhat normal temps between 50 and 70. The range I live in during the cooler months. It is bothering me this year. Health took a downward turn around thanksgiving. Odd.
    I tacked on a newer bank that is likely providing much of the juice.
    Thinking about looking for a small "shack" well south of Ensenada. For two reasons:
    Place to go if SHTF in US.
    Nicer winters.
  • littleharbor2
    You can definitely downshift a gear or two living down here. Punta Banda seems to be popular getaway south of Ensenada for my neighbor's summer cool down spot.
     Hope you are feeling better soon..
  • softdown
    Just some cloudy snowy weather.
