Add solar power to ebike
sgunts813
sgunts813 Registered Users Posts: 1
I'm trying to get a solar panel to put on my backpack to power my e-bike, the place where I got my bike said that I need no more than 2 amps to power 36v to 48v, any suggestions?
    2 amp panel @48 volts:
    2 amps * 48 volts * 1/0.77 panel+controller deratings = 125 Watt solar panel(s) minimum...
    You need to find out what the charger'/e-bike needs (min/max voltage, current, etc.)... Solar panels have variable power output and you need a fairly wide voltage acceptance range to work correct.
    Don't want to start a Lithium Battery fire with your e-bike.
  • Photowhit
    If you aren't familiar with solar panels, understand that 125 watts is NOT a size you would want to "...put on your backpack..."
    Also a backpack would typically not be a good orientation to get great efficiency out of your panel... AND anything blocking the sun from directly lighting your panel will cut the output 60-90%.
    FWIW - I'm a fan of cycling and solar. Pic cira 1999, from a 7000mile trip around the eastern US. That's a 10 watt solar panel on the trailer in the last photo that powered a light, fan, radio at night....
    A 125 watt panel of the most efficient panels would cover the trailer.
