Battery Banks not balanced
This and then this:
https://forum.solar-electric.com/discussion/358110/how-to-extend-battery-bank-time-of-failure#latest
When do you quit beating your head against the wall?Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat. -
Per battery voltages range from 6.27 to 6.34. SG ranges from 1.265 to 1.275. Battery Manufacturer says 1.275 is full charge. After multiple charging cycles, some batteries/cells go no higher than 1.265. When I set controller for equalize, 59.2 volts, the charger goes up to 58.4 volts and the amps level off at around 8 amps then goes no higher. After four hours I terminate the equalize.Residential Backup System Midnite Solar MN5048 Inverter/Charger 16) 235AH Crown CR235 8) Hanwha Qcell Peak Duo 350watt
