What if charging voltage rarely goes above 54.4 volts?
softdown
softdown Solar Expert Posts: 4,081 ✭✭✭✭
1) Panels are designed for winter efficiency. 45 degree tilt at 37 degree latitude.
2) Have a lot of freezers and the largest one seems to be going out. The compressor is usually running.
I suspect that lead acid batteries may get by with these charging parameters. Have read that AGM batteries prefer to float at full charge for several hours/day.
Educated perspective?
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,198 ✭✭✭✭✭
     54.4 volts is float voltage. FLA batteries need to see higher voltage to agitate the electrolyte and to keep from stratifying and developing sulphur crystals on the plates
     Are you under paneled and simply not making as much power as you are using? If this is the case your situation will worsen.
     Are your charging setpoints set higher?
  • softdown
    Thanks, guess things may be OK. Thought float voltage was higher than that.
    Charging setpoints are factory Outback.
  • littleharbor2
    That is 13.6 x 4 for a 48 volt bank.
