Is this a 2-wire start?
coryd
Registered Users Posts: 1 ✭
Hello all,
New to being off grid, putting together a solar system and want to confirm that this generator would be able to "talk" to the inverter and auto-start/shut-off based on battery levels. I have no idea what to look for in features/specs to confirm 2-wire status but was recommended this generator.
https://www.walmart.com/ip/DuroMax-XP13000HX-13-000-Watt-Portable-Dual-Fuel-Gas-Propane-CO-Alert-Generator/783922308
I don't see anything that indicates that generator has built in autostart capabilities. End even if it does, the autostart is probably just simulating the On/Off switch and in this case a pushed button to start. VERY important are controls that allow for generator warm up and also cool down. Also error handling and there can be more than a few possible errors and what should happen if a given error happens. That means you need to be able to understand the programming/settings for all the automation. You don't mention the planned Manufacturer/Model of your solar's system components and this is kind of important (wink).
Lastly, can this stuff be monitored, controlled and/or reset remotely, including error conditions via internet?Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
