Insight-home
latinhawk
latinhawk Registered Users Posts: 36 ✭✭
I just got a new Insight-home gateway. For several years I have been using the Conext Combox. The equipment works fine locally but it wont communicate with the cloud. I have tried everything I can think of to no avail. My Combox never had cloud communications problems even after the transition to the new insight website. Any ideas on how to make it work?
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,091 ✭✭✭✭✭✭
    You probably are going to have upload some screen shots. The one below is basic, are you getting that?
    E-mail offgridsolar@sti.net
  • latinhawk
    Thanks Dave. I I'm on version 1.09. Different screen than yours.
  • latinhawk
    I upgraded to 1.12. Time and date are correct but it marks them red.
  • latinhawk
    When I try to create the site on insightcloud.se.com all the fields are correctly filled in but the create button doesn't work.
  • Dave Angelini
    Recheck your time setting in Insght home. It has to be configured for your region. Nothing will work if time is not correct. Good Luck!
  • latinhawk
    Puerto Rico is not available. I am using Canada Atlantic time which is -4 the same as us.
  • latinhawk
    I just changed to La Paz same -4 time and it accepted it. However says no cloud connection string present.
  • latinhawk
    Eventually after much trying I left it alone and it started working correctly. I just installed a second 60-150 schneider charge controller. I can see them individually on Insight gateway local. The only thing that baffles me now is that on the main screen in power flow it only shows 1 charge controller instead of the two that I can see on the devices screen. If anyone can tell if that is by design or if there is some additional setting to adjust. Thanks.
  • Dave Angelini
    By design. You have to dig deeper to find the screen with just the mppt's. Hurricane coming your way?
  • latinhawk
    Thanks the lord it missed us this time. I know there is a way to adjust the battery voltage to match a meter. Right now one controller is slightly off the reading of the other. Tomorrow will be the test day. It was almost sundown when everything was done.
