Schneider MPPT 60 150 Blank LCD no breakers flipped
ericsysmin
Registered Users Posts: 6 ✭✭
I woke up this morning and it appears at 7:50am PST my brand new Schneider MPPT 60 150 LCD is blank and SCP/Conext Gateway showing it offline. Sun is out, the other 2 MPPTs are working fine. It was installed 3 days ago and was working great until this morning. Any ideas on what to check?
The first thing is to verify there is battery voltage at the battery terminals on the controller with the PV disconnected.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
