96 volt bank and mppt with 2 x 48 volt inverters ?
spacebass
Registered Users Posts: 87 ✭✭
As title suggests can I have a 8 x 12 volt series lithium battery bank fed by a 96 volt controller with two 48 volt inverters taking off from two points on the battery bank permanently wired ?
Thanks x
Thanks x
You can, but you won't like what happens. The batteries will become unbalanced and if any of the gear is grounded, you could short out 48V+ to the 96V+ Boom !
