can anyone recommend a good Battery load tester
MEK1954
Registered Users Posts: 23 ✭✭
I see a lot of automotive battery testers on amazon that are rated for CC amphr batteries but can anyone recommend a good Battery load tester that would work for 200 amphr battery's.
Your inverter !
Figure out how you want to test the battery, at the C20 rate, or for a 10 min max load.
Size the load on the properly rated inverter, and start cooking ! Use a DC clamp on ampmeter to verify the load calculation is correct.
Use a DC voltmeter to monitor the battery sag & recovery voltage
However, most true deep cycle batteries don't have a CCA spec, and many have a peak allowable surge spec (max amps) before the internals start to melt
Headlight application from older vehicles. Old sealed beam 12VDC lamps are inexpensive."we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net
