Northerly climates "require" all black solar panels.
softdown
Solar Expert Posts: 4,081 ✭✭✭✭
All but two panels are ~96% black. All black except for the narrow aluminum strips connecting the ~5" x 5" collection squares. They show about 1' of snow at the bottom. It is snowing.
The two panels that are ~88% black? They have aluminum colored triangles between each collection square. They show about 2' of snow at the bottom.
The difference is very clear.
Digression:
At about 2:30pm MST, system voltage is running between 49.5 and 50.0 volts. A bit alarming if it keeps snowing and tomorrow is crummy. So I fired up the diesel genset. Bit stubborn with a 2012 battery. Ran it for 10 minutes. Charging the 2012 battery now - clearly its last season.
May have to charge the batteries via genset. They took a big hit when I left for 2 1/2 weeks in September. It seems like an aggressive equalizing cycle was carried out to the AGMs - while I was gone. The Outback MATE internet interface is now removed.
Digression:
