Thoughts on adding a dishwasher to my system?
We have and use a dishwasher. It's a energy star model, and uses a no heat dry cycle. Only use it mid-day with full sun, and it is really useful in saving water, with only about 2.5 gallons per complete cycle. it's 120V, I would have preferred 240V to keep the inverter a bit more balanced, but it works fine
Thanks Mike, Could you share which brand and model. I didn't know they were able to operate without the heat/dry cycle.mike95490 said:We have and use a dishwasher. It's a energy star model, and uses a no heat dry cycle. Only use it mid-day with full sun, and it is really useful in saving water, with only about 2.5 gallons per complete cycle. it's 120V, I would have preferred 240V to keep the inverter a bit more balanced, but it works fine
We have a Bosch, close to 10 years old,
Almost all dishwashers nowadays, have a no heat dry cycle available via a switch on the front panel
Just for a reference, especially with small homes of 2 or so people. Nothing will save water like a double sink with a 1 gallon or so tub in each sink. The rinse sink gets used for plants. This is an old sailors strategy as the ships cat got the rinse water.
Not for everyone for sure but guaranteed to save water. The Bosch line is amazing! I still have a coffee bean grinder that my Dad gave me."we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
Good news on the Bosch line. As to water conservation. Here, at least, the water is brackish and seemingly unlimited. Still good conservation tips for the general, fresh water consuming folks.
We have a Bosch. If I had to get another, I wouldn't even bother looking at another brand. I did wire it on a switch in case there was phantom draw, but turns out the power switch is mechanical and there isn't any. They can have a fair amount of draw at some points in their cycles (more than 50 amps@24v). We tend to stage it's use with the laundry and vacuum unless it's full sun. It uses water, so likely the water pump will come on when it's in use. We have two 4024's, but with water pump, laundry, dish washer, and vacuum plus regular loads like lights all at the same time and you are starting to push on a single 4024. Not only that, you will be looking at possibly a 200a draw on your battery. So we just stage things like this. No reason to run equipment at or near peak loads. Sounds like that is what you would do.The Bosch we have has a quick wash which is ~33 minutes and does a better job than using a sink. Otherwise a wash is an hour or more depending on the cycle you choose. We don't prewash the dishes like some people do. The only draw back is that this type of unit expects you to open the door once the wash is over. This is so that the dishes will dry. When you open the door, a whole bunch of steam will be released which will drive up the humidity in the room. I'm not sure if other manufacturers are the same. IIRC, some have some type of drying cycle. Maybe that is what Mike was talking about.
Thanks for the info.jtdiesel65 said:We have a Bosch. If I had to get another, I wouldn't even bother looking at another brand. I did wire it on a switch in case there was phantom draw, but turns out the power switch is mechanical and there isn't any. They can have a fair amount of draw at some points in their cycles (more than 50 amps@24v). We tend to stage it's use with the laundry and vacuum unless it's full sun. It uses water, so likely the water pump will come on when it's in use. We have two 4024's, but with water pump, laundry, dish washer, and vacuum plus regular loads like lights all at the same time and you are starting to push on a single 4024. Not only that, you will be looking at possibly a 200a draw on your battery. So we just stage things like this. No reason to run equipment at or near peak loads. Sounds like that is what you would do.The Bosch we have has a quick wash which is ~33 minutes and does a better job than using a sink. Otherwise a wash is an hour or more depending on the cycle you choose. We don't prewash the dishes like some people do. The only draw back is that this type of unit expects you to open the door once the wash is over. This is so that the dishes will dry. When you open the door, a whole bunch of steam will be released which will drive up the humidity in the room. I'm not sure if other manufacturers are the same. IIRC, some have some type of drying cycle. Maybe that is what Mike was talking about.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
