Magnum 48 volt inverter question?
icarus
Solar Expert Posts: 5,436 ✭✭✭✭
Here is a question...Magnum spec say that the working voltage of the 48 vdc https://www.magnum-dimensions.com/sites/default/files/manuals/spec/MS-series_datasheet_64-0200-RevN_web_3.pdf inverter will accept 36-67 vdc. would it be possible to run this inverter on a 42 volt battery bank? The reason I ask is, I am designing a system, and depending on the number of panels etc, I begin to be in an under current charge current depending on the bank size.
For a number of reasons, I think I am going to go with T-105s rather than L16s since this system is going to be used by amateurs without trained supervision, so I would rather factor in shorter battery life with cheaper bank. To get to 48 volts means either 8 or 16 batteries. It probably isn’t a good Idea, but I’m curious. I can configure the CC to any voltage I want.
Yes, it "should" work. But being the oddball voltage, it's going to confuse the heck out of people !
Thanks MIke...
as I said, it was more a curiosity. Unless there is some real reason I can’t run put to 48 vdc that is what I will do. Too bad in some ways that nobody deals with 36 vdc on a regular basis.
Tony -
I think you are going to give yourself and others, a lot of grief with a 36V system.
Seriously, if you can't afford another battery, you really should not be getting into solar. Not as expensive as a boat, but more trouble than a 3 cyl motorcycle.
There are a fair amount of 36 VDC inverters on Amazon:
https://www.amazon.com/s?k=36+VDC+ac+inverter&ref=nb_sb_noss
Not that I suggest that as a solution unless there is a very good reason...
One benefit you might get would be if you prematurely lose a battery, (6 volt), your system will still be able to run till you get a replacement battery.
I am with Mike! I do not get it. Saving on an $85 battery? We design for the energy required on a regular basis. If you think "they" are going to not play by the rules, then you have to monitor it somehow. I have about 5 of these and most are easy to peak at. Some I have to call on a landline or cell. Usually only in winter.
It all gets added up next week and goes to the accountant.
E-mail offgridsolar@sti.net
