Pro Star Battery Status lights
GlorCafe
Registered Users Posts: 1 ✭
just recently our caravan was robbed of our battery charger 12v fuse panel and brake safe . we have just picked up from the repairer and find the Battery Status lights are green and red lights flashing and yellow remains steady. What does mean? any help greatly appreciated
Welcome to the forum
Morningstar LED fault sequence is red solid on with green and yellow will providing indication of fault type, the only time red will flash, that I'm aware of, is high voltage disconnect on load output, RG sequential, do you have a battery connected?
Morningstar support is excellent, they will usually reply within 24 hours on week days http://morningstarcorp.force.com/?cu=1&fs=ContactUs&l=en_US they will answer your question1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
