New to Wind & Solar
hmongsolar
Registered Users Posts: 6 ✭✭
If I wanted to add Wind Turbine, Can I simply just wire the Wind Turbine to my Battery Bank along side with my Solar Controller?
What's described would need an extremely large system, forget the 1000W kits, this kind of energy demand would take some serious equipment and $$$. When planning for off grid living, energy conservation is key, unless of course there's no limit to the budget, then anything is possible. Advise your not to buy anything without a plan and load calculation.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
