Catchment water system
Ainokea
Ainokea Registered Users Posts: 1
I live on the Big Island of Hawaii. We have rain catchment systems here. We have a 20k gallon rain catchment tank powered by a 220v Grunfos pump. We have a solar company installing a home system to power our 110v outlets (no lights), however they will not power our 220v water pump. Is there a way that we could power this 220v pump with its own solar panels, inverter and battery?
  • mcgivor
    Anything is possible what's the specifications of the pump and what so of run time are you looking at ? Using gravity in the form of a raised holding tank will greatly reduce equipment required and could eliminate the need for a large battery. There are other options such as pumping directly from solar but this would require a different type of pump, a 3 phase with variable speed drive.
  • Estragon
    Generally speaking it's simpler and cheaper to build a single system capable of running all loads if possible.  Higher voltage load(s) can be powered by either a separate inverter  on the battery bank, or by an AC transformer.
    As Mcgivor says, it would help to know the details of the pump, and also of the system being installed.
    Off-grid.
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,083 ✭✭✭✭✭✭
    edited December 2019 #4
    Actually the grundfos is probably already 3 phase internally. Is it an SQ or SQE ?
    E-mail offgridsolar@sti.net
  • MichaelK
    MichaelK Registered Users Posts: 236 ✭✭✭
    Can you put a hold on the home installation?  The problem I would guess is that they are installing an 120VAC only inverter.  My cabin has a 240VAC Grunfos pump, which I am powering via a Schneider XW+6848 inverter and solar.  It's wired just like a regular house main electrical box, with L1, N, and L2 going from the inverter to the main power panel.  L1 to N is 120VAC, L2 to N is 120VAC, and L1 to L2 is 240VAC.  So, half your home's breakers go to L1, the other half to L2, and both to the pump.  That's how you get both 120 and 240VAC at one location.  Both Schneider's Conext and Outback's Radian series of inverters can handle this.  I'd talk to your installer and find out why they are not installing a 120/240V inverter?
    System 1) 15 Renogy 300w + 4 250W Astronergy panels,  Midnight 200 CC, 8 Trojan L16 bat., Schneider XW6848 NA inverter, AC-Delco 6000w gen.
    System 2) 8 YingLi 250W panels, Midnight 200CC, three 8V Rolls batteries, Schneider Conext 4024 inverter (workshop)
