48 to 48 efficiency
dmadone78
Registered Users Posts: 1 ✭
Hello everyone,
im currently designing an off grid ev charging station and would like some possible insight and expertise as far as most efficient charging methodology . The system will consist of 1200 watts solar to a 48 volt mppt charge controller and then to my 200ah lithium ion batterie bank. From there I need to charge 2 48 volt 14 amp hour lithium ion batteries individually. Can I connect them both directly to the load on the charge controller or do I need to run from the charge controller load through a dc to dc converter first. Id like to charge each batterie at a 2 amp rate ,
Thanks, appreciate any input
You would need to limit the current to the smaller batteries because although a 14Ah battery is likely capable of accepting 14A, or1C, the array may/will subject them to overcurrent, they will accept far more than what is safe, so be careful.
What chemistry are you dealing with? Do they have a BMS attached?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
