how to connect these solar panels for solar pump?
ayman
Registered Users Posts: 1 ✭
Hi every one,
we have this pump and we need to know how to connect the panels (350 watt panels) as per the attachments.
pump:
Panels:
Max power (W): 350
open circuit voltage voc(V): 48.2
short circuit voltage isc(A): 9.66
Voltage at Pmax vmp(V): 39.3
Current at Pmax imp(A): 8.91
Module efficiency -nm(%): 18.1
pump:
Power max. 1,8 kW
Input voltage max. 200 V
Optimum Vmp** > 102 V
Motor current max. 14 APanels:
Max power (W): 350
Welcome to the forum Ayman,
Can you tell us a bit more about the pump motor?
If I am reading your pump specs properly (1.8KW/ 102-200v(dc?) 14 amps, you said described PV is not likely to drive that pump by themselves. The PV themselves, wired in series would only put out something like ~100-120 vdc at ~8 amps. You have 1.8 kw of load, while only having ~1050watts of pv. Under the BEST circumstances that PV might put out ~800 watts, leaving you 1kw short...unless I am not understating your specs properly.
Tony -
Most solar pumps will simply run at reduced output when there is less than rated watts (eg, 3 panels in series). But more info is needed.
Hi here is a tutorial video that may help you with the calculations https://www.youtube.com/watch?v=9AmxsH59jOc&list=PL_Pa7uRjhyODHRjN4ALT9im7XkPsrqqyq&index=2andYou have to take account on the peak power generated in your system to avoid damaging the pump
- 228 Forum & Website
- 898 Solar Product Reviews & Opinions
- 653 Solar Water Pumping
- 619 Discussion Forums/Café
- 312 In the Weeds--Member's Choice
