Looking for advice
jk6672
Registered Users Posts: 2 ✭
i want to piece to a solar power system for roof top tent camping. My basic power needs will only be a Dometic fridge, coffee maker, charging Mavic pro drone batteries, and running LED camp light around the tent and awning. I’m not sure of what wattage I should go with, I don’t want to cut myself short, and I don’t want overkill for tent camping. I have a 3500 RAM truck with dual alternators and optima red tops, but I think it may be best to connect the inverter to one or two lithium 100ah batteries with solar for recharging. I’ve been looking at Renogy, Aims, and Xantrex products. I am thinking of either butting this in a portable case or mount in my trucks Leitner design pod storage boxes.
I’m new to Roof top tenting and trying to get a feel of maybe what others power consumption is to I can start piecing together a system. Are the brands I’m looking at quality or should I be looking elsewhere? Footprint is important to me also, do to space limitations of cargo room for roof top tent camping.
I'd start by checking the power consumption on the fridge. Some can be surprisingly high.Off-grid.
Also, the power (Watts) & energy (kwh) to charge up the drone batteries. If you have a cook stove, you're better off using that for the coffee.
It’s about 13.5 amps and 176w on a 110v outlet for about 1/2 an hour to charge three packs.
Need to understand better your numbers... Note that Watts (and Watt*Hours) are "complete" units. They "fully" describe the rate of electricity use (Watts, like miles per hour) and amount used (Watt*Hours, like miles driven).
13.5 Amps and 176 Watts...- Power (Watts) = Voltage (Volts) * Current (Amps)
- Energy (Watt*Hours) = Voltage (Volts) * Current (Amps) * Hours
For example,- 176 Watts (rate of energy usage) * 1/2 Hour = 88 Watt*Hours (to charge three packs--All three packs total, or 88 WH per pack?).
And you have different types of refrigerators. The standard compressor type (something like 1,000 WH per day full size fridge). Or 250 WH per day small/efficient fridge).
And you have propane/120/12 volt absorption type fridge (Ammonia). On propane, they take something like 1 lb of propane per day. On 120 VAC or 12 VDC, they are very inefficient and typically not worth doing on solar.
500-1,000 WH per day solar power system is "small" and enough for lights, a small 12 volt water pump, charging a laptop and cell phone, etc.
3,300 WH per day is enough to run a small/efficient cabin or very efficient home (full size energy star fridge, LED lighting, Laptop, TV, solar friendly well pump, washing machine.
On batteries... A 100 AH * 12 volts = 1,200 Watt*Hour of stored energy. Whether Lead Acid or Li Ion. And roughly, you don't want to discharge your batteries more than ~50% before recharging (and with Lead Acid batteries, you need to recharge them to >~75% state of charge quickly--Or they will sulfate if left to sit for days/weeks/months). Propane refrigerators (may) use a relatively small amount of electricity to run the temperature/flame controller.
The suggested path to follow:- Choose your more efficient/low power loads you can (LED lighting, laptop/tablet computers, etc.
- Typically use Propane (other fuel) for cooking--Although, for small amounts of hot water/etc., possibly solar will be OK
- Measure your loads using a Watt*Hour meter like the Kill-a-Watt (120 VAC) and/or a DC Amp*Hour/Watt*Hour meter
- Define when and where you will be using solar (American South West in the summer, Skiing in Canada in the winter)
- Will you have a tilting solar array? (farther north you go, tilting array can increase your harvest)
- Will you be parked in shade/valleys/wooded areas? Will you need to have remote panels (100 foot away) in sun while you camp in shade to keep cool?
- Do a few paper designs of your system (loads->battery bank->Solar Array).
- Then start looking for hardware (buying hardware without a plan, generally difficult to configure a workable system)
https://www.amazon.com/s?k=kill-a-watt+meters 120 VAC Energy/Power meters
https://www.amazon.com/s?k=dc+ah+wh+meters DC Energy/Power meters
http://solarelectricityhandbook.com/solar-irradiance.html Solar Harvest calculator (hours of sun per day by location/month/tilt of panels
For the solar harvesting, more or less, >3 hours per day is "solar friendly". Less than ~3 hours per day, solar becomes less able to supply heavier loads.
No problem "running the math" for you--But would really like to understand your loads/seasons of camping/loads a bit better first. Otherwise, things get a bit confusing with me throwing out meanless (to your needs) numbers.
I've never tried to put solar arrays on a tent.I'm thinking of a ladder rack on your truck, and PV array on the rack, park the truck in the sun, and run power to the tent.A fridge is a really heavy load, propane fridge or dry ice may be worth considering.Don't forget about the little 1kw inverter generators, they don't use much fuel, and are really quiet. No expensive PV panels to mess around with, just gasoline.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
No generator is quiet enough.A 12V fridge will be his heaviest load, but I don't consider it a heavy load. Like BB said, about 250wh for some. My 4.5 cuft uses more than that. With a 125ah 12V battery I'm rarely below 80% SOC in the morning. My loads are the fridge, led lights, phones, and a little cream warmer thing that the wife has to use. Sharpen your pencil on the numbers, but since Li-ion can tolerate deeper discharges, one 100 ah Li-ion might be enough. Renogy is decent budget stuff. I had their 100W portable suitcase panel which got run over and became 50W. Two of those might be good for you. Xantrex is OK, but I'm not satisfied with my truecharge2 because the charging parameters are not configurable.
