4 x 100w solar panels and one 30a charge controller?
1911
Registered Users Posts: 51 ✭✭
hello,
I recently ordered 4 x 100w SunPower flexible panels.
I already had a Morningstar Prostar 30 w/ display.
Do I need a second charge controller or can the 30 amp cc handle the 400 watts?
specs on panels:
specs on panels:
- Nominal power: 100 Watts
- Power tolerance: +6 / -3 Watts
- Vmp: 17.1 Volts
- Voc: 21.4 Volts
- Imp: 5.9 Amps
- Isc: 6.3 Amps
- Module efficiency: 18.8%
Thanks!
Morningstar has a string calculator which is is extremely useful for finding out the best configuration http://string-calculator.morningstarcorp.com. Without knowing the proposed nominal voltage and assuming worst case scenario 12V, it would appear a single 30A controller would be all that's needed. All panels in parallel 4 × 5.9A = 23.6A actual would be closer to 75% of rating so 23.6 × 75% = 17.7A so within 30A maximum.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
FWIW my 4 100 watt panels 18.9 voc
5.29 imp ( 21.16 total) with 30 amp pwm almost every day in summer I see 22 amps. edge of cloud flashes 24 amps.
Has been working 3 years.
- 232 Forum & Website
