Inverter size relative efficiency.
spacebass
spacebass Registered Users Posts: 87 ✭✭
Thank You Bill for last wisdom.
If a brand range of inverters have the same efficiency (92%) per model how can using a bigger inverter in the range cause more conversion loss than a smaller one ?
  • Estragon
    92% would be maximum efficiency.  Operating efficiency could be much lower.
    For example, you could have an inverter using 40w just being on, running a 5w load.  40w x 24hrs is ~1000wh vs a 5w load (5x24 =120wh), so 12% efficiency.
    Off-grid.
  • mcgivor
    The efficiency will differ depending on load, at low or high loads the efficiency won't be at maximum, usually it's somewhere in between. Often in the specifications it will be stated where in the performance curve this peak occurs, so using an oversized inverter to power small loads may likely cause it to run inefficiently, whereas a smaller unit could be in its sweet spot with the same load, idle consumption aside.
    Obviously every inverter has its own specific characteristics and not all will provide detailed information but simply the peak efficiency. To test this use a DC clamp on ammeter to measure the battery current preferably with resistive loads on the inverter, then measure AC output current output, with a simple conversation ratio 10:1 for 12VDC  to 120VAC  for example, you will be able to determine the losses. Try various loads to understand where this sweet spot is, probably a waste of time for the most part but interesting none the less.
    On page two of the specifications for the MorningStar 300 Watt TSW 12 volt inverter, they have a nice curve of efficiency vs wattage (this is an "official" MorningStar link):
    https://2n1s7w3qw84d2ysnx3ia2bct-wpengine.netdna-ssl.com/wp-content/uploads/2014/02/SureSineENG_R2_1_08.pdf
    https://www.morningstarcorp.com/products/suresine/
    For larger AC inverters, many will have parallel switching units that add up to the high wattage output... I think I read one place that at least one of the Schneider/Xantrex XW units would turn off some of the parallel switching sections to reduce power use and increase efficiency at lower AC output loading.
    Anyway, here is a ~6 kWatt Context XW+ manual. You can go to page A-9 or ~132 for an efficiency graph of the AC inverter:
    https://www.solar-electric.com/lib/wind-sun/Conext-XW%2B-NA-Owners-Guide.pdf
